Window Seal Protectant/Cleaner
What is the best product to clean and protect the rubber seals around the exterior of the windows and black plastic pillars b/t the supercrew doors? I always seem to have overspray from other cleaners in these areas and I am hesitant to hit them with Armor All. So far I have been lightly using a multi-surface cleaner to remove spots, but I'm sure this isn't the best solution.
Originally Posted by 2stroked
For the rubber seals, I'd recommend 303 Aerospace Protectant. It may sound a little wowy-zow, but it's truly great stuff. Spray a little on a rag and then wipe it on the seals.
I've always applied a coating of "silicone spray lubricant" to my rubber door seals. While I've read in several forums that the use of this product in this way is not advised, I have found it keeps the rubber seals of my vehicles looking like new for years???
My use of this product began when I lived back in Minnesota, as the lubricating properties of the spray prevented doors from freezing shut during the cold winter months.
Originally Posted by RockPick
Exterior?
That's a painted metal surface - not plastic. It's thin metal but, it's, indeed, metal.
Treat it like paint.
RP
RP
303 or Vinylex are two of the favorites on the market.
You can find 303 at just about any RV shop.
