Wood cleaner overspray
Old 06-05-2006 | 12:34 AM
dantheman1973's Avatar
Hey guys,
I need help...
My neighbor cleaned his fence with a biodegradable, non-bleach, wood cleaner/brightener. Unfortunately, it was windy day, and I got a funny mist all over my BLACK SCrew (02' Lariat)
I washed it - notably 24 hours later - which didn't remove it.
I clayed it - which didn't seem to do much either.
I did manage to get one fender cleaned, and looking quite nice, using Meguiars Medallion Premium Paint Cleaner. But it took some serious elbow grease. I tried orbital - but not nearly as productive as by hand.
I believe the main component of the deck wash is oxalic acid (since it's non-bleach).
I didn't know if anyone else has experienced similar, or if anyone has any thoughts on how to make the job a little easier (took over 1 hour to get all the spots off 1 fender, and the spots are covering the entire truck).
Dan
Old 06-05-2006 | 04:36 AM
kingofthegeeks's Avatar
Give your neighbor some polishing rags and some more maguires!
Old 06-05-2006 | 11:10 AM
Rockpick's Avatar
Moderator &
Tough one.... if the MPPC was yielding results, it sounds as though you may have a very slight acid etch and thus, you'll have to abrasively polish everything else out as well... MPPC is a fantastic product (one of my favorites -- go figure, it's discontinued and I only have two bottles left).
My suggestion -- find a detailer experienced with rotary buffer use (not an orbital -- not a DA) and let him do a panel for you.... stay with the vehicle and watch. If he/she can remove it on that panel, odds are that they'll be able to remove it everywhere... at that point, it probably becomes well spent $$ -- otherwise, you might just be p'sing into the wind on taking care of it (sorry for the pun).
RP
Old 06-14-2006 | 12:46 AM
New Discovery
Hey guys,
thanks for the replies...
In the process of continuing to clean the truck... I was able to come across a new discovery.
I was cleaning the chrome step bars with Eagle One Wad Polish (contains petrol distillates).. and it magnificently removed the wood cleaner residue.
Got me to thinking to try bug/tar remover on a inconspicuous area.
well it worked... Gunk brand (not sure if they still make it) in spray bottle worked great at removing quite easily the residue.
There still are a few marks, leading me to agree with RockPick that there's some etching...but may not be as bad as I had first thought.
Also, RainX window polish (denatured alcohol) removes the residue from the windows well.
Just thought I'd share my serendipitous discoveries.
Dan
Old 06-14-2006 | 09:32 AM
Rockpick's Avatar
Moderator &
It sounds as if the solvent-based products may have done the trick... glad to hear that it worked. While these wouldn't have been products that I would've suggested, I am glad that you solved your problem and didn't cause more...
Now that you've pulled it off, remember that the solvent/petroleum products that you used removed not only the wood treatment overspray but also your wax... it'd be a very good idea to do a full detail at this point to revive your protection layer.
RP
Quick Reply: Wood cleaner overspray
