Clay Bar Questions
Clay Bar Questions
I'm about to clay my truck today. I just gave it a really good wash and got all the dirt off. Now I'm ready to clay.
Is there a particular brand that everyone likes?
Any tips/tricks?
And after I clay can I apply wax, or do I have to wash it again?
I tried a search and got 1,000,001 htis, so this is just easier. Thanks!
Also, can I clay in direct sunlight, or is that not a good idea? Garage space is kind of limited at my house.
Any tips/tricks?
Any tips/tricks?
Any tips/tricks?
Your paint will feel silky smooth when you get done. It's pretty cool.
you should be able to do your truck in 1-2 hours.
Any tips/tricks?
Any tips/tricks?
Thanks for all the advice guys. I went and got a ClayMagic bar and did it this afternoon. It was a lot easier than I thought. This was the first time I ever used clay and I will continue to use it now. The paint was SO SMOOTH after I was done. Then I waxed it and now the finish is unbelieveable!
JP
Originally Posted by RollingRock
I was so impressed how the paint felt after I did the treatment....question now is, how often can you use the clay bar? What is recommended?
JP
JP
I believe after you are done with it you should throw it away. I cut mine into 4 pieces after I unwraped it for two reasons. First, I would have a backup in case I dropped it, and secondly, because I only used 1/2 of it for the truck. Now I can use the other half in a couple of months when it needs to be done again.
Sorry, my question is how often can you use the clay bar treatment on the paint? What is too much or not enough?
Different environments will yield different time schedules on claying... for example, in a heavy industrial area or near a railway, you'll find yourself needing to clay more often than if you're in suburbia and garaging the vehicle every night.
RP
Originally Posted by RockPick
The answer to this one is "as needed". Assess your paint before and after every wash and/or detail cycle. If the paint feels 'rough' to the touch, it may be time to consider going back to the clay bar to remove the bonded contamination.
RP
RP
