OK to spray engine bay with hose?
Originally Posted by Lumadar
...So I think newer engines might be better off than the older ones.
Again though, like you mentioned, just because you use water in an engine compartment doesn't necessarily mean that you're going to have problems... it's just that one time though -- that's all it takes.
Originally Posted by RockPick
Interesting perspective. I'd probably flip-flop that in my opinion though... electrical instrumentation has come a long way wince the late 80's.
Maybe the newer engines have MORE electrical- it's just better protected?
We barely hosed his and it filled with water in a few places. Where as I've never experienced that with hundreds and hundreds of brand new cars.
I mean, think about all the massive cosmetic plastic covers in the engines these days comapred to the older cars? Maybe they play a part in "shielding" certain aspects of the engine that would otherwise have problems from the water.
VADER716, Ford wants to speak to you
Something about desecrating your truck, and the fact that maybe you should not have such a nice truck to destroy. Maybe you need a ricer to go Muddin with, everyone likes to see those trucks abused. But no one likes to see a $ 30K truck brought down to salvage value, by playing in the mud.
The kids were in the back watching a DVD while Daddy was flooring it through mud pits and off-road trails.
I keep inviting RP to come run his garage queen but so far he keeps ignoring me.
Video of just the mud part (about 20 seconds long)
http://video.google.com/videoplay?do...75554755772654
Originally Posted by vader716
I do it but I'm very cautious. In fact the owner's manual recommends it and shows you what should be covered.
Now I would never do anyone else's but I do clean my motor.
Engine degreaser, Castrol SuperClean, brushes and hose.
I've never had a problem.
First Post New Member
Not knowing any better I've always washed my engine off 4-6 times a year while at the car wash. I washed my new FX4 Scab yesterday for the first time. The engine bay was covered in a fine sand from sitting on the dealors lot. I always make shure the engine temp is not to hot. Over twenty years of doing so with no problems yet. I will keep my fingers crossed and go with what has worked for me.
Clean clean clean
I just removed everything like That plastic thing on the top of engine The power steering bracket and everything else that was in the way(even my intake), blew it off with compresser and got in there with a rag tooth picks and q-tips (i love my truck very much) its took me about an an hour and a half but the time flys when you start seeing results enother good idea if your are EXTREMELY CAREFUL is a powerball an a drill for the valve covers
Powerwashing the Motor
I have done my 01 Screw, 05 Screw 2001 Mustang, 93 & 97 Sables.
All with my own Pressure Washer, 2500-3,000 Psi, 45 Degree Tip,
But I always have them Running while I am Doing it, 2-3 Minutes and then
I shut down the Engines and I ALWAYS Blow Dry The Motor and ELECTRICAL Components and Everything Else Under the Hood off with my Toro Electric Super Leaf Blower, Not just for Leaves anymore!!!! Works Great. I have not had a Problem in 12 Years. Then I Wash the Vehicles off, and I Blow Dry them off with the Leaf Blower also. Gets all the Water out of the Power Mirriors, and all the nooks and Crannies, I even Blow Dry the Rims and Tires Off.
But I have never had to use an Engine Cleaner such as Gunk engine Degreaser or other Chemicals. just my Experiences. But these where all with FORD Products. Maybe GM isn,t as Water Compatable??
Seriously just my 2 cents worth. KR Paul
Originally Posted by tbizzle
It's a truck for crying out loud. I'm thinking it is supposed to get dirty.
Anyway, I keep my motor bay mint, here's how I do it:
The only thing I cover is my open air filter element with a small plastic bag. Then I spray down the entire motor bay with Fantastik with OXY. Let it sit for a couple minutes then I lighty rinse with my Mr. Clean autodry filtered water. Then I hand dry with dry microfiber rags using Eagle One Wax As You Dry on all plastic parts and WD40 on all metal parts. I then let it sit for aleast a hour just to make sure it's all dry before starting it. A added bonus of using the Fantastik with OXY is that when you turn your air on, you have such a nice clean scent. Three years old non-garaged:
Holla...
