clay bar residue, can I wax on top of it, or wash the truck over again?
Originally Posted by RockPick
wait until your paint has a 'texture' to it... in short, you can feel stuff stuck to the surface that isn't washing off with normal washings... then give it a whirl.
RP
RP
oh forgot to mention i ended up using the clay since i ran out of the cleaner. I also noticed it is mild clay so im guessing they have different grades. But i could see all the stuff coming off and on the clay. unreal how much was there after washing the truck. But in order to fix the texture i think i would have to some wet sanding. not sure if i want to put that much work into it.
Originally Posted by nditech
Man good thing you changed it to stuck to the surface. The texture of my truck is very discourging. Not sure if i want to detail it again. Very disappointed in my golf ball textured truck. This is the first truck that i have owned that has that much orange peel in the paint. Not sure if it has anything to do with assy plant but my last 2 came from canada.
Roger that... worried me there.
Even with the wet sand though, some OP is in the base rather than the clear... hence, gotta remove all of the clear to get to the base... hehehe... I love automated robot painting!
