Under the Hood
I usually stay away from under the hood. If and when i do clean under there, I usually use simple green. I spray simple green all over lightly and let it sit. I use a light spray to wash it down with the engine running. After it dries off I use, elbow grease and simple green to wipe everything down.
I use a combination or Simple green, QD and water (seperately, not all mixed together) with cotton and MF towels to clean under the hood by hand .. then I spruce it up with Meg's Hyper Dressing.
I have never been an advocate of spraying water under the hood, although a lot of people manage it with no problems..
My preference is to use a citrus-based cleaner (ie: orange clean) and mix in a very diluted ratio. Use 1 rag wet with this solution and 1 rag wet with normal water and 1 dry rag. Use the cleaner 1st, water 2nd, and wipe dry 3rd. This prevents messing up the electronics, while cleaning everything. Also, the citrus cleaner prevents damage as opposed to simple green. Also, interior detailer solution/meg.s vinyl/rubber protectant works great.
But, some prefer to spray on engine degreaser and simply hose off, which works well for some and wreaks havoc for others.
I'll bet, though RP has some suggestions
Originally Posted by Padron
I like all your rides Red Lariat,
Where can you get your engine Steam Cleaned and how much does it cost?
Alot of gas service stations used to do it, but I don't see them anymore.
Anyone use the Meguairs Detailer line Degreasers?
I have no ideas on the price of someone steam cleaning the engine. I bought my own steam jeanie from a coal mine supply company years ago. It is diesel powered and should last me a lifetime.
I use Black Magic Engine Shine. It says you don't have to cover up anything and you can spray anywhere in the engine compartment. I was skeptical at first, but it works really well. Of course, even though it says you can spray everywhere, I didn't really take too much of it to the intake. I did use it normally on all the wiring. Wait about 15 minutes and spray down witha steady stream of water. I've had absolutely no problems with it. It comes out clean but not too shiny. I'll try to remember to take pix next time.
