Rotary/DA/Etc...
Rotary/DA/Etc...
Just out of curiosity, I am looking at getting the G-100, but was just thinking... I have an air compressor and tank...Does anybody make a pneumatic buffer/rotary/DA/etc. that works well for detailing? If so, how does it stack up to the G-100? And, how much do they cost?
Thanks ahead of time..
BTW- If anybody needs any detailing stuff, talk to Rick at ADS. Best customer satisfaction EVER. I have never done business with anybody as eager to help the customer as Rick is. Great guy, very professional, and exceeds the highest standards of customer satisfaction I have ever seen.
I have a 6" DA that came from Snap On. I hesitate to use it on my truck because even after draining the tank and water filter your still gonna get some condensation coming through it. Also, you have to oil the air units and some of that is subject to being sprayed out the exhaust port on it.
The other thing that keeps me from using it is that I only have a 5 hp, 30 gal tank and the DA sucks a lot of air so the compressor is running alot. And, the hose would be a lot harder to keep off the car than an electrical cord is.
Some day may give it a try though.
Chicago, Central and Astro all make air d/a's.
As for oil & water separators, Milton, Devilbliss and others, make them separately and as combo/piggback units.
Expensive? Not really, unless you want the air so clean it's fit for an OR.
Water only units start around $25. Oil & water units are a bit higher ($175-225).
SL
SL
http://search.netscape.com/ns/boomfr...om%2Fdeli.html
Heres one I found on the net. Go to polisher and pads.
I guess pneumatic isn't for me, b/c I only have a 6 gallon tank...and they said you needed around 60 gallons of air. Not to mention I only have 2 HP, whereas they say you need 5-7.5.
Oh well. worth a try to ask. Maybe when I get a really nice air compressor (ie: around 60 gallons and upwards of 5 HP), I might give this a shot. But, this'll be a long way down the line.
Thanks for all your help, though.
Originally Posted by 05supercrew
I have a Craftsman professional 25 gallon 2 stage. I might try it. Is a 60 gallon really needed if you do small sections at a time?
Most body shops have huge (120-200 gal) tanks with 2 or 3 cylinder, high (10-15) HP compressors for multiple loads, high CFM and fast refill times
Originally Posted by snappylips
Depends on how small "small" is. The reason for the CFM spec on the tool is to ensure that the compressor has the ability to provide continuous air for non-stop use. If the tool's CFM requirement is higher than your comp's ability, you'll run out of air. If you're only doing a quarter of a panel at a time, and smaller tank will suffice, but having to wait for the tank to refill gets old after a while, especially if you're almost done and run out of air.
