Scrapes??
Old 09-23-2006, 06:25 PM
TXhustla's Avatar
Originally Posted by RockPick
Lastly TX, you need to be aware that you only have so much clear to work with to 'remove' this problem. Concealing it may not be a bad option if you're not comfortable going after this scratch in a more aggressive fashion. While I know you'd like to work with the products on your shelf, I would probably recommend adding one more (to the tune of around $8) so that you can attempt to handle this in a better fashion than simply trying to 'wax it out'.
But, even before I did that, I'd probably hit it a few more times with the Scratch-X... how many times have you tried it? Are you doing it per the instructions?
RP
I used it three times. But its not a little scrach its a entire side but its still not deep. Only time it is seen is if your right up on it or sun is bright. Would it matter if I did it a few weeks after it happended??
Quick Reply: Scrapes??
