Washing MF Towels
Washing MF Towels
I was wondering how you guys eliminate the static electricity in the MF towels? I ordered a new batch from Exceldetail last week and washed them over the weekend. I held off on putting a Bounce sheet in the dryer, as recommended by almost everyone, but these things were full of static when I took them out. Should I let them air-dry or what?
I just deal with the static...
Fabric softener will reduce their effective use because fabric softener is designed to 'coat' each fiber with a waxy type of substance that yields the fiber 'softer' to the touch (and bouncy fresh!)
Hence, when you coat the fiber, you reduce it's effectiveness.
My suggestion -- deal with the static... *shrugs*... not sure what else you can do.
-RP-
-RP-
Check the external ground on your dryer. Some cities don't require it to be hooked up at all. Ours doesn't but I hooked ours up anyway due to how electrically unstable the area is. We haven't had a single article of clothing or any of the MF towels have any static.
Anyway, the theory of the "dryer ball" is only going to work if you have a good load of towels. The ball basically keeps the towels from flattening out against the drum. When they flatten out, and slide across the drum, thats when your static charge builds up.
Too bad there's not a simple way to discharge it another way. Since static electricity will discharge to something with a lower charge, maybe we can find a way to build something cheap to help discharge it or to shift the positive charge to negative.
