Windshield question: spots and frost-like markings
I've had this for a while and maybe those experienced can assist me with this dilemma.
I seem to have "spots" on my windshield and what seems like crystalized stuff. They look more apparent when humidity takes place.
Anyone know how to fix this outside buying a new windshield?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Here's what I use:
Invisible Glass and a clay bar will remove it all...make sure the bar is new, as a bar previously used on the paint can transmit dirt and worse to the glass.
As y'all can see....this is my first post here. I'm a detail freak...and an ex Ford number dummy.
Thanks....
I always clay glass. It's a standard part of any detail that I do. It's the last part to be clayed when I do it...
BTW, what you're probably seeing is the result of HARD WATER. The crystalization that you're seeing is most likely calcium carbonate (limestone) as a result of HARD WATER.
Clay should remove it if it's not etching into the glass. Additionally, the vinegar trick should probably do some for it...
Beyond that, try THIS.
RP
RP
