Buffer and scratches?
i have an extreme ammount of surface scrathes from offroading with my black truck and my friend claims his buffer can do the trick with waxing as well. Does the correct use of a buffer and the right chemicals and wax really do the trick; if the scrathes pass the test of fingernail passing scratch without getting embeded?
is there any pre-emptive things i can do to my paint so next time on the trail my paint won't get eatin alive?
-thx-
-thx-
Typing on my handheld here...excuse typos.
A 'buffer. is a loose term. Some scratches will come out; others will not..
Black is a booger. That would definitely be a consideration to just letting some guy work on your paint. He may be a crackerjack and, yes, a buffer and the right chemicals can probably do a lot but, by the same token, if not used correctly, can induce problems that can't be fixed.
Preemptive.... stop four-wheeling. HAHAHA!
Hope that helps a little...its tough to type on this handheld.
-RP-
-RP-
if he knows how to use the buffer then have at it. ive got a few friends that have stuff and say they know how to use it but i still wouldnt trust them. buffers can lead to some serious damage on paint.
other than that, yea, a buffer will remove quite a few surface scratches and make your truck shine.
First of all thx for the input, but honestly im not going to stop off roading, i have an FX4 and im just doing what it was born to do, anyone who has a 4x4 and just keeps it shiny and pretty without doing any wheelin is just a poser. i do however hate the unsightly scratches i get from the trail. i really want to know what i can do to prevent it, and quiting wheelin isnt an option. i want input to whether there are professional products to put on the car, or even redneck half-assed methods. ( maybe putting mud over your entire vehicle will help )
-thx-
-thx-
that protective film stuff look like it could do the trick but i dont want to spend like $100 each time i go off roading so i have enough film 2 cover the sides of my truck. doea anyone make protective film that is bigger then 6in in width?
does any1 no if the film can be re-used?
any other opinions/ideas on how to protect paint?
