Rust prone area!
Rust prone area!
Have ya’ll noticed the gap at the bottom of the door where the door skin is crimped to the door? Mine isn’t crimped to the door at all! The gap is large enough to hold small pebbles and dirt and it acts like a gutter to hold dirt & water. And will for sure start to rust within a few years!! Anyway, I got some clear automotive seam sealer & filled the ‘gutter’ to keep it from holdin’ all the garbage but I left the door drain holes open. It wasn’t only all the front doors my tailgate also had this ’gutter’ at the bottom! Is Ford wanting these to rust? Anyway, just thought I would pass my find along to ya’ll..
Originally Posted by top_sgt
i'd try some silicone sealer..... home depot or lowe's type!!!
good tip. Yeah, mine has the same look to it, and I guess it definately has the potential for problems down the line. So, since at some point I'll need to do the same, could you tell us:
1. What is the name of the product?
2. How much is needed (and if you don't mind, tell us what # of doors you have so we can judge amounts accordin to our vehicle's size.)
3. If you could post pics, please
4. Lastly--In a moderate amount of time, please let us know how it's hilding up.
Thanks.
Thanks.
Thanks.
Thanks.
2. I will use most of the one tube on my truck, I had to go over the seams twice to fill them!!! But I'm gonna get another for to finish Dads F250 S-CREW. My truck is a super cab with 4 doors '2 full & 2 half doors' and of course the tail gate. one tube should do a single truck. Unless ya have the S-CREW with the 4 full size doors..
3. Pics comming tomorrow
4. Will keep ya posted..
Originally Posted by FX4_Off_Road
I was told not to use a silicone base sealer, that it is an acid base that will cause corrosion down the road. So I went with the automotive seam sealer I got from the body shop. but it wasn't enough so I gotta go back for another small tube..
