I need to polish some aluminum
I have a metal finishing shop and I can assure you that a store bought polishing cream is not going to polish out raw aluminum. First you need to sand the part with various grits of paper until you get a smooth 600 grit finish. Then buy a spiral sewn buffing wheel and tripoli buffing compound. Buff part till you achieve the desired smoothness then clean and switch to a loose cotton wheel with tripoli compound and give it the final mirror shine. At this point it will look like chrome and you can now use the store bought polish to maintain the shine. I personally recommend Mothers Mag and Aluminum polish or Flitz. You can get them at any auto parts retailer. Sounds complicated but the buffing wheels are not expensive and you can put them on a bench grinder for home use. With a little practice you will be amazed at how easy it is to turn rough aluminum into custom show parts for your truck.
If you are serious about it buy a kit from Eastwood.com.I had to do various parts for my truck and bought the basic kit.It came with various grits of paper that can fit in a regular die grinder or drill.That i used on my manifold.If it is regular flatstock or something not cast just differant grades of sandpaper up to 600.Then I also bought some buffers from Eastwood with three differant compounds to do the final polishing.Am very happy with the results and you can see them on my page.It does take a little elbow grease though so be prepared.
Thanks 98Navi, I've been at it a while mostly boat and motorcycle parts. It does take a lot of time to do a good job and if your afraid to get dirty then stay away cause without proper ventilation you will look like a coal minor in minutes. Once you get the hang of it though its well worth it!
