Foggy Headlight Lens??
Old 02-28-2007 | 01:15 AM
Firemed362's Avatar
On my 98 the lens are real faded or foggy looking. is there a product or any other way to clean these and make them look clear again?
~Heath
Old 02-28-2007 | 01:28 AM
Rockpick's Avatar
Moderator &
Meguiar's Plast-X.... as long as the 'cloudy' is on the OUTSIDE of the lens and not on the inside.
Old 02-28-2007 | 02:13 AM
Firemed362's Avatar
Ok thanks, ill try it, and what if it is on the inside, am i screwed?
Old 02-28-2007 | 04:41 PM
Rockpick's Avatar
Moderator &
If it's on the inside, it's likely a result of condensation/mineral deposits.
Check it out -- if it is, let's talk a bit more. My hunch is that it's on the outside and that the Plast-X will remedy your situation.
RP
Old 02-28-2007 | 11:36 PM
SlammaJamma's Avatar
I tried plast-x on mine, it didn't completely clean them. Then again it's my own fault for going so long without doing it.
Old 02-28-2007 | 11:45 PM
Rockpick's Avatar
Moderator &
Did you try multiple applications?
I've seen that stuff bring back some SEROIUSLY thrashed clear plastics. I mean, I've been speechless a few times... it's truly good stuff.
Old 02-28-2007 | 11:50 PM
Hawkpilot's Avatar
Gipraw's Avatar
I would second that .. the only thing I have seen work better is wetsanding with micromesh, and the Plast-X is a lot easier to use.
Old 03-01-2007 | 12:25 AM
qadsan's Avatar
I'll third that with the Plast-X...good stuff. I've also used good'ol Meguiar's #80 and other similar polishes with good results on plastic headlights with good results when I didn't have any Plast-X handy. It also works very well on most clear plastic intrument lenses as long as they're not lexan.
