Stock Chrome Wheels
Old 05-02-2007, 03:27 PM
Meatwagon's Avatar
Originally Posted by Xterrable
Dont forget, that the 04-on chrome 17's are actually plastic or thin tin.. They are a perfect fit "hub cap' that covers the steel wheels.
So does that mean you can remove it? I'm looking at powdercoating/painting these rims in black. If I can rip off this cap, it will be a lot easier than removing the chrome plating.
  #32
Old 05-03-2007, 10:35 AM
ldahlberg's Avatar
So what is the best way to clean a non clear coat chrome rim? Can you use a sos pad,magic eraser, simple green on them?
  #33
Old 05-04-2007, 01:21 AM
rustyzipper's Avatar
Wenol has been awarded “Manufacturer of the Year” from the prestigious International Show Car Association, Pacific Division. It is a staple on the car show circuit for its ease of use and remarkable results.
Wenol Blue contains chemical cleaners that remove stains, insects and tarnish from metal without attacking the metal itself. Once you buff away the polish, the metal will be coated with a clear layer of protection against moisture and corrosion. This coating enhances the brilliant shine and protects it for weeks!
http://www.wenol-polish.com/
Quick Reply: Stock Chrome Wheels
