0000 steel wool on windshield??
Old 04-03-2007, 10:28 PM
Rockpick's Avatar
Moderator &
Originally Posted by peakbagger77
Bon Ami powdered cleanser. And it doesn't kill your paint.
I wouldn't 'use' it on the paint... it definitely has some abrasive qualities being that calcium carbonate (limestone) and fledspars (another 'earthen' material) are primary ingredients. Additionally, I will go out on a limb here and say that the mix may be somewhat caustic (high pH) which can also etch paint (hence, hard water etching).
On glass -- I'd say you're golden. I definitely wouldn't let it get on *my* paint.
Old 04-03-2007, 11:43 PM
deapee's Avatar
Windex and a razor blade...gets ANYTHING off glass. I use it all the time when I get something on my windshield. Once you get good at it, you can clean your entire windshield (with 50 bugs on it from a weekend trip) in about 2 minutes.
Old 04-04-2007, 12:08 AM
Zaairman's Avatar
Would 0000 steel wool be able to take some scratches outta glass or am I just screwed?
Old 04-09-2007, 12:22 AM
rustyzipper's Avatar
Picked this up off of Auto Geek Zaairman.
Best way to get glass to look new is a cerium oxide polish for glass..it will give glass the new car look....use with a PC and a 4inch pad...glass turns into a diamond..removes scratches, smooths out pits, so less noticeable... use a 4" green or orange pad to polish glass...google cerium glass polish ...look at them all on the first and second page...prices vary...mine was $29.00.
Old 04-09-2007, 03:42 PM
Rockpick's Avatar
Moderator &
I'll give you a yell on IM.
Old 04-09-2007, 04:38 PM
Lumadar's Avatar
Well, I'm not sure what gauge we used... but when I had my first job at age 17~ at a Ford dealer we used steel wool ALL the time to clean glass and REAL chrome. Never once saw a single scratch as a result. Steel wool worked GREAT for us...especially getting the glue overspray/runoff off of the windows from the factory.
Old 04-09-2007, 10:58 PM
Rockpick's Avatar
Moderator &
Right... you can use the steel wool to clean them but, I really don't think that it's going to REMOVE scratches from his glass... it probably won't introduce any but I don't think that it's really going to remove them either... unless I'm wrong -- am I? (I honestly don't use the stuff very often).
Old 04-09-2007, 11:03 PM
SuperSport1985's Avatar
vinegar/window cleaner/rubbing alcohol all mixed together will take water spots off. Vinegar itself will take it off.
Old 05-10-2007, 01:04 PM
dennisfranz's Avatar
What about toothpaste?
**NOT FOR PAINT**
Old 05-12-2007, 04:53 PM
CRSmith05's Avatar
I have a SeaDoo that is yellow and black, had a big problem with water spots. Bought a product called "Ducky" at the boat store. It is advertised as a water spot remover. Took them right off. Might work on your windshields too.
Old 05-12-2007, 07:11 PM
chris1450's Avatar
I painted Kenworth trucks for more than 8 years. When they went to touchup paint shop, we used 00 steel wool to clean all the over spray off the windows. Worked great and left no scratches.
Old 05-14-2007, 11:23 PM
sambandit's Avatar
I have always used steel wool on windows and chrome with no problems at all!
Old 05-16-2007, 08:24 PM
911DISP's Avatar
I use a product called Bar Keeper. It makes it look new. The only place I know to get it, and laugh if you want Beth Bath and Beyond.
Quick Reply: 0000 steel wool on windshield??
