Bird poop stain
Bird poop stain
I live in Tampa,Fl and today the temperature was 86* and very sunny.As I was leaving work I noticed a big ole poop spot on my hood! When I got home I put some spray detailer on the spot and let it soak a few minutes.I used a micro fiber towel to wipe it off,which came off very easy.I noticed it left a stain behind.Is this now a permanent mark in my clearcoat/paint or can it be removed?
BTW,my paint color is Dark Blue Pearl Metallic.
Originally Posted by jenningsjh56
Clay bar, then cleaner wax, follow it up with a good carnuba wax or polymer wax for protection.
You're on the right track to removing it...
My suggestion is to continue to move forward with the polish that you're using to remove the problem.
If you removed 80% of it with one or two applications... one or two more should finish it up.
