Door seam rust preventative?
The seams were all sealed during production. On a lot of the 1999 through 2003 and even on the 2004 Heritage model there was an issue with rust along the bottom door seams, coming through from the inside. It was thought to having been caused by the drain holes along the bottom of the door being filled with mastic and or epoxy that is used as an adhesive agent during assembly of the doors. This would prevent the rain water and etc. from draining. Some trucks experienced it, and some didn't.
I hope that Ford has it all figured out now as I want those monthly retirement checks to keep coming from them....
99 SCab with Rust on all 4 of the door seams
I have rust and bubbling at the bottom of both the front doors and rear suicide doors due to the bad water drainage. Is there any advice out there on how to stop this rust? Sand it off with a rust/paint remover pad and primer it? Any idea how much a body shop would charge?
they did not use a sealer over the seams on the 02's and 03's doors or tailgate. my father's 01 s'cab was sealed completely around the doors from the factory. this is why your getting rust. i had mine fixed under warranty. remember your truck is covered for 5 years for any rust. i noticed my drivers door is showing some rust colour again. i will mention it to the dealer next week when i get it serviced. hopefully they will take care of it again without any problems. most body shops that Ford had that fixed this problem had a special tool they use to bend it back and clean it out etc. then they are able to pinch it without damaging the outside of the sheet metal then seal/paint. why they stopped using a sealer around those seams is totally ridiculous
wanted to add as well that i removed the silly plastic drain whatever's from the bottom of my doors. they seem to drain a lot better. i also get my truck oil sprayed every fall.
All trucks from 97 up have it on the doors and tailgate.My truck was oil sprayed every year and i still got it.
I read the ford fix is to open the seem sandblast prime and fill with panel adhesive then repaint.Read this either here or another forum board from a self proclaimed ford body shop guy.
cheers
cheers
cheers
cheers
Thanks.
