Minor rock chips
Originally Posted by 03gtmustang
I got this kit, http://www.autogeek.net/langka.html Havent used it yet though.
This is a discontinued product but, it actually works quite well as I've used it several times for customers and also on my vehicles (and need to use it again on my vehicles!).
$4 on Ebay
One thing is for sure about the Langka system... it works. But, do not expect perfection. It will GREATLY reduce the visible chip but, if you're down and on top of it, you'll still pick it up quite readily.
Originally Posted by mikelmco
So you all think the little touch up paint I got at Ford is not really good to use?
Mike
Mike
The Ford touch up paint just can't compete with wet sanding and a true base and clear coat (hell, the factory paint brand new off the showroom can't even compete with wet sanding, lol)...
Originally Posted by glc
Use it, but don't use the brush that comes in the cap except on large areas. Use a sewing needle to lay real small drops into the chip, don't let the paint flow out of the chip.
The Langka is not paint, it's something to use to level the blob.
Mike
Originally Posted by Lumadar
Mike, I tried and couldn't send you a PM.
Any other way to communicate? (I have the kits)
Many thanks,
Mike
