Wax For My F350
Yes it'll be PLENTY!
What color is your truck? I'd recommend you use the NXT as a base coat of wax followed with a carnuba if it's a darker color. If its a lighter color, just do two coats of NXT. Allow 12-24 hours between each coat otherwise you'll be wasting your time. I like #26 as a carnuba, it goes on and off amazing and gives such a wet look.
Originally Posted by skirk55
My Ford is dark red.
That said, if you do have problems, it can be a fairly effective product.
BEFORE:
AFTER:
Mind you, that was accomplished with 2000 grit, a bunch of elbow grease, and a rotary buffer with a wool pad.
Back to wax... you'll like NXT for simplicity and, as was previously mentioned, you'll definitely want to apply VERY thin (remember, you're only leaving behind a VERY thin layer of protection -- why waste the product by slathering it on?).
If you really want to step it up, you may want to further assess other options. I mean, I'm not sure if you're looking to spend 4 hours or are willing to spend 4 days on your truck. If you're more on the latter end of that scale, there are other products and procedures that you should definitely consider that will further remove any swirls and other problem areas (oxidation etc) that may be beneficial to your outcome.
Anyone can smack on a coat of a wax. It's the prep work that will end up yielding the high-end results that most demand -- not the last step wax product.
Good luck with your truck!
-RP-
