Black Plastic Help!
Black Plastic Help!
I purchased Meguiar's PlastX for all of the Black plastic on the outside of my truck. The PlastX did not make the parts look good so I used silicone base product and everything looked good but it rained that night and it ran down the doors the next day and I have to wash it off and re wax the area. What can I use to make the black plastic look good and not run down the doors when it gets wet?
303 Aerospace or Vinylex.
303 is available from marine retailers (like West Marine) or from select auto chains (Murray's in IL has 303). You can get it very easy via online ordering (Autogeek, for example).
Vinylex is available in spray/wipe form from Pep Boys.
Avoid Mother's Back to Black like the plague!
-Mike
-Mike
-Mike
-Mike
Black WOW is really good stuff but it is hard to get. Always out of stock.
http://store.northamericanmotoring.c...?productid=144
When in doubt, read the directions -- as they say.
As was previously mentioned, two very respected products for dressing/protection are Vinylex and 303 Aerospace Protectant. Both are water-based. Unfortunately, you may find that both products will run slightly; not excessively, slightly.
The unfortunate fact is that if it's water-based (which almost ALL of them are these days due to air regulations), when it gets wet, it will go back into solution and transport some of the silicones and other materials in the mix thus causing a smear or streak.
The bad news is that there is NO silver bullet for this. All you can do is apply, remove excess, and deal with it on occasion.
-RP-
