Pressure Washer
I dont think that its a good idea. Use a good washing procedure and the pressure of the tap water should be enough to rinse the suds off.
But if you arent the type to actually wash, but more rise, than whatever is cheap if you are going to buy one, and the lowest setting if you already have one. G'Luck!
Thats what i thought as well...the high pressure rinse is what i like best about the car wash but i never want to take it their because of the harsh soap. I didnt wanna get something that was going to blast my paint off though either...just help get it cleaner..so around 1500 is good...i was thinking about getting the 1300 but if 1500 is safe than that is it..thanks
Originally Posted by emig5m
I use a gas powered 3700 PSI 4.0GPM 13HP pressure washer with a 25 degree tip BTW.
those graphics on the quad are cheap... just stuck on there to improve the visual appeal while on the showroom floor... I have always removed any type of graphic tape/ sticker when i get a new quad... because eventually those graphics will start to crumble away like an old sticker soaked in water and the glue will streak down the paint...
but no worries on a vehicle... just dont get real real real close and use atleast a 20* tip and you are GOOD TO GO! on the Undercarrage I use a 15* or sometimes a 10* depending on how muddy or dirty it is...
