I'm made as hell
Originally Posted by STXDriver
I just discovered that a new White F150 can't be parked under a Pecan tree unless you want big ugly Yellow stains on the truck that won't come off.
I've tried everything I could think of to get the stain off with no results.
That sucks if none of these worked...
oh yes the joy of having pecan trees....i have found that clay usually does not work on the "pecan stains"...it usually happens when a rain comes down and washes the sap from the leaves...sits and then dries on to truck. try a good cleaner wax...i am not familiar with meguiars numbers but i think #7 or is it #21 that is a good cleaner wax. this should do the trick with just one coat and doing it just by hand. if it is your house you will find that the stains will become dark in the winter that get washed off the pecan trees. i have also heard that pecan trees are "self pruining" meaning that the limbs fall off very easy...dont know if that is true or not.
many hear know about the meguiar numbers, but i have cleaned the pecan stains before, a simple cleaner wax alone will clean it....i dont think the clay did anything, which i found odd, it could be the acid and base/ph properties of the stain and wax that broke it down.
let us know what you do and how it works
rockpick..if its like i have seen...the truck will be clean and will feel smooth and look shiny from a distance...it will just look dingy, an not just in one spot, prob the entire hood panel...it is usually alot worse on the hood and roof...and not that bad on the side.
Try Color-X or the A-line cleaner wax. Or any other cleaner wax fo that matter.
Yeah... I've seen similar instances. Almost like a metallic rusty looking blob stain (for lack of description) but, it's not necessarily on top of the paint but more of a very slight etch and a light stain that goes with it? I don't see much tree staining here (unless it's pine sap/tar) but, some chemical fallout in and around this area will mimick that problem.
As was mentioned, a good cleaner wax (mother, meguiar's, etc) will likely work on a problem such as this but, you will or may have to focus your work on the spots. Also, as was mentioned, the Color-X option (available at your local 'mart' store typically) is probably a good choice here. The reason being is that it's more of a solvent-based cleaner wax (with some fillers (kaolin etc) that can remove issues similar to this...
-RP-
![devil](https://www.f150online.com/forums/images/smilies/devil.gif)
Originally Posted by MeanGene
How about using baking soda and water? I know it works on bird droppings. It will neutralize the acid in the bird poop. Not sure if a Pecan dropping is acidic or alkaline.
![Frown](https://www.f150online.com/forums/images/smilies/frown.gif)
Originally Posted by RockPick
It'll neutralize it but, it'll offer no help for an etched mark into the clear. One would have to be standing by, bottle of basic mixture in hand, to combat bird poo immediately. The longer it sits, the worse it becomes. As it dries, it looses much of the acidity as the acidity is conveyed by the moisture in the poo. ![Frown](https://www.f150online.com/forums/images/smilies/frown.gif)
There were those FMC commercials from a foreign country that killed birds and cats...(JP has the link)...
