does wax really help??
Originally Posted by cdnance
any reccomendations? it seems like i always need to turn my rotors. only thing is that i dont drive or brake very aggressivly (spelling). should i just go with new rotors and pads?
the thing is that i keep getting that jerky feel when braking like the rotor is warped or something. as far as pads, i have car quest on them now but the dust is awful.
If you are using anything over +2's you are going to get some shimmy in the braking. This will also account for exessive pad wear and heat due to larger/heavier wheels/tire combos.
Just a thought incase you are using larger wheels.
Originally Posted by ThumperMX113
Yes. I use to use NXT but found it to last a lot less compared to "Wheel Wax" It's a little different than a normal wax when applying it but its the same basic concept, I'd recommend it.
PS: You've probally got a warped rotor.
and yeah the rotor is warped, but it always happens within about a month of changing them out. but i am using the stock set-up. and i dont do any aggressive stopping or anything. who knows.
I have seen rotors that seemed warped but it really was brake pad material transfered to the rotor. The way it happens is you go down a long hill and have to stop at the bottom. Your rotors are very hot and you hold you foot on the brake pedal while sitting still. Pad material sticks on the rotor.
Not saying that is it for sure but could be. I have used the park brake when traveling in the mountains while stopped at a traffic light so the barkes could cool. Just remember to release them. LOL!!!
Oh, yea and use NXT on my Clearcoated Chrome wheels.
Tic
Tic
