Did a 5 hour detail today
I started by washing with Gold wash.Then I did the claybar thing.I had it clayed about 3 months ago but it seems they did a quicky job.I then washed it again and "interstate" dried it.When I returned home I blotted any wet spots with my huge microfiber towel.I then did the Meguiers 3 step system;cleaner,polish,then wax.Oh,I also did under the hood too.I used scrubbing bubbles,rinsed,let it air dry then sprayed everything down with silicone spray.
I have pics to show my work but don't know how to download them here.Any help on how to do this?
BTW,my arms feel like "Popeye" arms after all this rubbing!
You dont ever want to detail after a drive through carwash. The only time to ever detail is after a good soapy, suddy, bucket wash and rinse. Drive throughs only get the grime off, non of the real stuff.
But you can always bucket wash at the drive through..... They usually frown on that tho.
wash, rinse, run the water over the body panel to sheet most of the water off, leaf blow all the cracks starting at the top. You should be able to get about 80% of the water off with the blower. The way I get the rest is spray Megs Ultimate detailer on the truck in sections and wipe the truck down with a Megs waffle weave drying towel. Works great everytime for me atleast. Good luck, oh and it helps if you have a garage, carport, tent, ect.
If you have compressed air, its even better then a leaf blower. Like stated I feel the best way to truly dry a car is run flowing water over from top to bottom to sheet the water away, then use compressed air/leaf blower to blow the air out of the cracks then finish up with a SOFT towel that was not dried using dryer sheets, these create tiny scratches and over time add up.
This time of year it's usually raining or about to rain when I wash the truck (As the sun sets 4-7 pm). Drying is for winter months. (I live in SW FL). I washed my truck Sunday, and had to take a lightning break. I later found out there were F2 tornados messing things up only 5 miles away. My windows are spotty, but then again it's rained on it twice since I washed...
