Hard water stains on paint
So, I did a quick search and couldn't really find anything. Is there any other way than an acid wash to get hard water stains/deposits off my wife's paint job? It is water from a water sprinkler that has caused horrible stains/deposits on one whole side of her Explorer. It was a couple of weeks of water from this sprinkler when she noticed after getting it washed...I can't get her to wash her car more often.
Thanks for your help.
There are not 100's of threads here, you can search all of them in under 5 min.
JP
Originally Posted by RockPick
Are the stains etched into the paint or are the minerals sitting atop the paint?
Did a better search...found some talk about it.
How's this Bar's Best Friend? Is this still recommended? I'll try the vinegar/water mix...but I'm reluctant to use clay (never used it before) on the whole side of a vehicle less than a year old.
The spots are on the paint, correct? If so, UNDER NO CIRCUMSTANCE SHOULD YOU USE BKF ON THE PAINT!!!!!!!
The vinegar trick may work to a certain extent if the spots are ON TOP of the paint. If etched in, you've got some serious polishing to do to remove them.
BTW, clay is ultra simple and probably safer than the vinegar mix. Really -- there's nothing to worry about here.
I'll have to look at it closer when I get home. I ran my fingers over it and it felt rough.
So I have a Black 2005 F-150 and I had some water spots, and what not that I wanted to get rid of. When I would rinse the truck I would get that beading and spotting Vs sheeting.
So I went and picked up ICE liquid clay bar. I did half the hood and then rinsed.. HUGE HUGE difference. The untouched side just beaded and looked like crap, the cleaned side just sheeted off and kept a perfect gloss until the water dried. My neighbor was amazed when I showed him how it worked.
Great, Very easy to do, no worrying about dropping clay, and it works real good. You should definately try it and when you do, do one side of your hood and then rinse to see the results.
The 'Liquid Clay Bar' is simply a chemically aggressive polish. It falls considerably short of accomplishing what true clay does. BTW, the liquid clay bar concept has been around for quite some time - it's not a new concept (search Diamondite).
Also, the reason that I've been asking about if the water spot seemed like it was sitting on top of the paint or if it was etched into the paint was to help him determine what he needs to accomplish the task of removal. As several have suggested, if it's on top of the paint, it's likely that clay will remove a good portion of it (likely not all) but, if it's etched from hard water, clay will accomplish nearly NOTHING and will be a general waste of time with regards to removing the spot.
So, before we all jump in and slather the pig, let's make sure we can help him accomplish his goal...
-RP-
Using a clay bar is going to be your best bet. It's not hard either. Just do a panel at a time. Use a bunch of QD and run the clay across the paint. Bead the clay every so often. Once you're done with a panel, use a MF towel to wipe off the QD.
Ice Liquid Clay Bar? What the hell is that? Do any of you other detailers know what that is!?
-RP-
http://www.turtlewax.com/main.taf?p=2,1,1,4
