Scratch Advice *PICS*
#46
No wetsand
Originally Posted by Favre
BTW- Built Ford Tough is true, my bumper doesn't even have a little dent or crease, and the rear quarterpanel on her civic is smashed in like 2 inches.... Just some tiny scratches left on my truck.
I used ScratchX, Meg's Cleaner Wax, and Goo gone and got it looking pretty good.
#48
Originally Posted by RockPick
Little known fact -- I'm a fat ***. I played soccer in HS (many tens of pounds ago). I was heavily recruited by several DII colleges and ended up playing for a couple of weeks - until getting cut -- at a DI AA college in Illinois. You guys?
What position did you play? You kinda remind me of a forward... Fairly small, probably wuick, and creative...
I play Outside Midfield... My favorite position. I only have to think of moving in one dimension, and only can pass in 3 directions... My job is easy... I just run a lot (hence the Cross Country Varsity position I hold...)
Any other takers?
#49
Originally Posted by RollingRock
Does it pain you Zaairman that I have TWO now?
Going to rent it out to F-150Sport for 500 perday but shhhh he doesn't know that yet.
#50
I dunno what position RP played, but I do remember him saying that he was a pro referee or something like that... My sport has been working. Just wish it paid more...
#51
Originally Posted by Dr. Franko
Who do you think you are telling people they can't have a discussion because you know best?
Obviously you don’t know enough to know that color sanding a COMPLETE vehicle with 2,000 is common practice.
unnecessary personal attack deleted
color sanding a complete vehicle with a factory finish .. eh .. not always so safe.
as RP mentioned.. you didn't mention filling first when you talked about the sanding .. just because you know what you are doing, when you are giving advice in an open forum like this, you need to assume that the person you are giving advice to doesn't have that knowledge.. so what seems like common sense to you, may not be so obvious to them, and leaving simple things out of your comments can cause issue for someone that is trying to follow advice step by step.
Secondly .. as RP touched on . there are several steps between ScratchX and 2000 grit. Off the top of my head, I can't think of very many times where going from hand work to sandpaper is the correct answer. I would almost never recommend removing scratches with 2000 grit without first attemping defect repair with a machine and abrasive compound ..
Always use the least agressive method possible for defect removal.
and to answer RP's comments .. I was a powerlifter in college .. now I am a power eater
#52
Originally Posted by Gipraw
color sanding a complete vehicle with 2000 grit that has been repainted by someone that knows what they are doing is a common and safe practice if you know what you are doing with the sandpaper, and the buffer.
#53
But then what do I know, I've only had 30 or more personal cars and maybe another 1,000 that I bought and sold as a dealer.
BTW, what kind of Dr. are you?
Proctologist by chance?
#54
I mention doing some light wet sanding with super fine grit and you go off like I said to take to take a grinder to his truck. Whatever.
#55
Personal attacks now hmm? Go back to cleaning your truck boy.
EDIT, I think we beat this one down, I give you win. Extending an olive branch.
Truths? Firends? Amigos?
#57
Originally Posted by DrFranko
Yes
#58
I told him to lightly wet sand and then polish. BTW I've seen a lot more paint jobs ruined by a buffer burning the paint than I have by light wet sanding with 2,000.
the simple answer is the less aggressive method should be tried first.
