Cloth Interior Cleanup-good Results!
O.K. here it is. Little kids have accidents, and sometimes smelly pee and puke just gets to ya so bad that you have to clean up the inside of your truck. My 2002 F-150 has the gray cloth interior, so heres what i tried.
I get a hold of the wife's Bissel little green machine. it has a spray/agitator
vaccum head for cleanin little messes on carpets. Also has a resevoir for
your favorite liquid cleaning solution. The recommended bissel green machine
liquid was my choice
1.) vaccum out truck as much as possible, with a regular vaccum.
2.) Use little green machine to spray areas down. allow to soak for a minute
3.) go over the areas with the vaccum agitator head. and suck the moisture
right out of the seat.
4.) Go over the areas you just cleaned with a dry towel. rub it really good.
you will be surprised at what comes out after you have vaccumed!
(Don't let the wifey catch you out there with her good towels )
I was pretty impressed at the results, and drying time with the towel got the areas pretty dry. An hour later, the interior was dry and looks 100% better. and smells better. think ill top it off with some febreeze
Maybee I'll do the van tommorow!
Originally Posted by stud_135
Sounds great man..i have been contemplating the LGM vs. a Steam cleaner...how did you find the water lift to be in the LGM (sucking power of water)? Also was there a lot of moisture still in the seats when you finished..and did it seem humid inside the truck? Thanks!
I have an extractor and a steamer and couldn't live without either one!
Well that is the part i am not sure of...mostly (right now) i just do my own personal vehicle..with a few friends nothing too high volume and im kinda tryin to budget because i still need a pc and a few other cleaners/waxes/and such so i am tryin not to break myself but i dont think an el cheapo' would be the best bet right now...what do you think what is the most bang for my buck?
2.) There was a little bit of moisture still left in the seats, but wiping down with a clean towel really drew the rest of the moisture out.
3.) The humidity was'nt bad. with the towel drying of the seats and carpet, after about 1.5 hours, all parts of the interior felt dry. no humidity.
- although the temp was about 85f. outside, and sunny. i left the windows up just in case it wanted to rain that day.
Hope this helps
