Buffing Out Faded Headlight Lens??
You can't see it too well in this picture, but the plastic lenses on my wife's 1991 Mustang are really faded to the point the thing is really bad to drive at night. I ordered one of those "Headlight Polishing Kits", and UPS says it's coming today. Has anyone ever used one of these. I would think they are all pretty much the same. Some type of buffer that goes into an electric drill, along with some type of polishing compound. I was wondering if any of you guys had any experience with them? Also, if this deal works out I'd like to install a new set of those really bright "blue" headlight bulbs. Does anyone know the brand name of these things? I see them from time to time on cars and trucks and they look substantially brighter than regular Halogen bulbs. The way I see this deal is if I buff the crap out of the lenses, and install these new bright lamps, I'll be able to actually see where the hell I'm going at night. Right or wrong? Comments please. Thanks in advance, Mel
I'm not familiar with the Meguires "Plastix" product. Is this a polish that requires elbow grease like any other polishing compound?, or is it a preserving liquid? Rockpick really know what he's doing to make a vehicle look like that. I'm afraid I don't have his talent level in making "A silk purse out of a sows ear"! Mel
Plast-X contains diminishing micro-abrasives that slowly break down on the plastic as they are abraded against the clear plastic.
The Mustang lights that I featured in that one detail were an absolute b*tch! There's no other way to put it. I wet sanded, I polished (high-speed with a high cut pad), I plast-X'd them, I plexus'd them... it was a major PITA.
I think you'll find that the headlight restoration kit that you've snared -- like many of them out there -- seem to work okay. The toothpaste trick can be used but, if they're really foggy (like you've described), you'll really have your hands full (and a very sore arm from buffing them).
My suggestion -- get your kit, follow the directions, and take some before and after photos.
If that doesn't work out, let's talk a tad more about what we can do to them.
Best of luck to you and thanks for the kudos, by the way!
-RP-
-RP-
-RP-
What is required? Some type of transformer or alternate power source? Mel
Run a search on here for HID lights. There are several that have made the modification to their trucks.
One example: https://www.f150online.com/forums/sh...hlight=ballast
My '04 F-150 has no foggy headlight lens, but my daugter's Toyota was really fogged. I first used Turtle Wax paste that has a slight grit to it plus hand rub. Very little help. Then I used Turtle Wax Rubbing Compound and whipped out my Porter Cable. This did it, but not easily. Those who want to use their toothpast may want to check their tooth enamel. The grit level of your toothpaste has to be amazing.
