Water Spots on Glass
How cool! I've been using just about whatever I could get my hands on around the house to try to get some really stubborn water spots, some etched into the glass, off of my windows. I finally broke down and pulled out the PC with a cutting pad and some Meg's SR 2.0 and went after them. They are gone!
Anyone see any potential problems with this? The glass looks really great.
They are gone!
Really... the PC isn't going to generate enough RPMs to really use a cutting pad effectively. In fact, with #9 (Swirl Remover 2.0), you'd probably not want to use a cutting pad...
The reason is that #9 is much more of a 'filling' product than a 'remover' product. As such, since you're 'filling' the problems, a FINISHING PAD would be a much better choice or a POLISHING pad at the worst.
f-150sport03
Next time, you might try Bar Keeps friends, etc. Do a search on here-- you will find a LOT of great info for future reference.
Perhaps I should have been more clear. I've used any products mentioned with no success. Perhaps my application was at fault, but nevertheless, the spots remained.
uhhh.... PC+ cutting pad = okay.... Megs SR 2.0??? Are you talking about #9? I have heard and used the Poorboys SSR 2 (and a LOT more products), and have heard of #9: Swirl Remover 2.0. Is this the one?
not yet. I bet your neighbors got a kick out of it, though...
RockPick
I tried the finishing pad first. No luck. I went with the polishing pad. Not much luck. The cutting pad started taking the spots off..........and they're really pretty much gone.
It seems like my post wasn't well received. I just thought someone would like to hear about what I was able to do.
If you're the one who constantly refers folks to the search function, please take me off of your list. I did that. Thanks.
........the cows scarcely paid attention.
What the problem was
How you figured out the problem (in this case: above vs. etched into glass)
Each step performed, and how well it worked
Why you chose the method you did
whether you would do it differently if you had to do it again.
With all that info, we can readily visualize your situation and more clearly understand what and why you did what you did (I hope that makes sense).
Olive branch?
