Blood on Leather
Wow! Nice rides... My friend just bought a '07 Frontier with the v6, 5 speed, and the 4x4 NISMO off-road package.
I've driven it quite a few times already.... but it's kind of small for my tastes. But hey, it's pretty peppy too and it sits up high.
Originally Posted by RollingRock
you should call color new....there are several locations in TX...they are good at this type of fix.
http://colornew.com/locations/
Originally Posted by 01SILVERGT
Yeah, I got a Crew Cab LE (the only model offered with leather) and I really like it. It was between the Fronty or the Titan for me (LE Fronty or LE Titan were within 2k of each other from my dealer) and I really did not need a big truck, nor did I want another gas guzzler (have the Armada for that) so I chose the Fronty. It is pretty peppy, I have the 5spd auto, IIRC the manuals are 6spd.
What part of the seat are we talking about?
As for a good 'maintenance' cleaner, Meguiar's Rich Aloe Leather Cleaner is a pretty good choice. Readily available and very effective.
Also, keep in mind that a HOT washrag that is damp (not saturated) is a very effective cleaner on today's coated leathers (and associated vinyl panels adjacent to the leather).
-RP-
-RP-
-RP-
-RP-
I've gotten everything off I can, there is still a light stain left. I'll try the Megs cleaner also.
Top of the seat.
Also, the Meg's cleaner probably won't touch it if it is seemingly 'stained'. It's pretty good at MAINTENANCE on the seats but, when it comes to spot cleaning, it's not all that great.
Top of the seat in the middle panel or top of the seat on one of the bolsters?
it goes across both.
I hit it again with a HOT rag and followed up with megs. Its MUCh fainter now than before, but its still there. FYI, this is on a Nissan, so not sure if the leather is different than Fords.
Good info.
The reason I was asking about the location is that, in most cases, the 'leather seats' that the manufacturer will tout are only partially leather. This is true on most FoMoCo products as well as many other manufacs out there. In short, only the center panels on the seats are actual leather. The other parts are pleather or vinyl.
Keep going with the HOT rag... The Meguiar's Rich Leather, almost definitely, WILL NOT remove it. It's worth a try but, it's just not an aggressive cleaner -- it works fine for your every day cleaning to remove some grime and ground in crud into the texture of the material but, much beyond that, it's not a good spot cleaner.
Let me know how that works out. What other cleaning chemicals - from an all-purpose cleaner standpoint do you have around?
Can you get us some pics?
Good info.
I will take pics later and post them tonight.
So, anyone know how to get blood off leather? I cleaned most of it off, but there seems to be a light stain left. :o
Also, need a recommendation for a good leather CLEANER for tan leather (never had tan before and it shows stuff fast).
Originally Posted by Shinesintx
Peroxide, Peroxide, peroxide. It is very simple, and should not harm your leather. I dont want RollingRock to crawl up my butt, so I will explain how it works. Peroxide, is water (H20) with an extra hydrogen molecule (H3O) When the peroxide meets blood, there is a chemical reaction, and the extra hydrogen molecule floats of into space...leaving H20...water. Peroxide is THE best method for removing blood in fabrics such as cotton. PLEASE NOTE: I have never used it for cleaning leather. So, use at your own risk.
H30 is hydronium, a cation of water, and I dont reccommend this for seats
H2O2 is a great idea-- removes blood from stuff really well...wish I had thought of that.
