Finshed up the 250 this morning
Nice Job
[QUOTE=RollingRock]Stayed up until 1 am working on the paint under the lights last night, got early and finished up.
Didn't want to go too crazy on this one so I stayed away from SSR3. I did try a section with Optimum but I wasn't seeing the results I wanted even with a Lake Yellow cut pad and the DA on 6. So I went to PoorBoys.
What I used today:
I ran into a lot of old product build up (See other thread) which added some time to the process.
The results
First your toy looks better then NEW awesome job.
1. Did you Clay first?
2. If you would have Clayed, would it have removed the old product?
3. With all the old product on the paint to protect it, way would it have anything wrong with it the paint that is?
4. I have been under the impression that you would like the buildup. What is wrong with letting it build?
5. Glazes and polishes do they build up or is it the wax?
These are just question and not criticism, your truck looks great and no one can argue with that. What a testimony to the PoorBoys products also.
What pads did you use with each step?
Thanks for all the great information
For all the sun ****'s.
More on the next post
There are 52 photos of this detail here, http://s188.photobucket.com/albums/z...F250%20Detail/[/QUOT
These are just question and not criticism you truck looks great and no one can argue with that. What a testimony to the PoorBoys products also.
That pads did you use with each step?
E]
What I used today:
The results
E]
JP-E]
JP-E]
JP-yes after washing using Dawn, claying took 2.5 hours to so.
JP-I used Megs Blue and it was't comming off, so I used some ScratchX to take it off quicker then reclayed the area. I only had build up in 6-10 places.
JP-Not sure I follow this one.
JP-hard to really answer this...old product build up is a result of stacking and "patching" until you can take it all off and start over. My situation was that I had been hunting a lot which gave me a lot of micro marring and some new scrathes then I got my liner put in which marred up my tail gate pretty good. So rather than doing a full detail several times I tried to cover up some of the marks with various products as a tempoary fix until I can go at it.
JP-This was stacked wax. PoorBoys Nattys toped with Quick Wax Plus (Some one wrote on my tailgate in the dust so I fixed it with the QW+, that is again a temp solution)
These are just question and not criticism you truck looks great and no one can argue with that. What a testimony to the PoorBoys products also. JP-Thanks, I am pleased with the results.
- SSR 2, Yellow Lake Pad
- SSR 1, Green Lake Pad
- Pooboys Polish, White Lake Pad
- EX-P, Blue Lake Pad
- 845, Megs Foam Appliactor.
Hope that helps.
Cheers
BTW, I am IN LOVE with this MF's
JP
