Wax for chrome?
Most "chrome plated" parts - including wheels - are NOT clear coated. The reason? Very simple actually. First, "Chrome" plating is generally more than just chrome. Better chrome plating is a 3 step process involving Copper, Nickel, then Chrome. (Sometimes called "triple chrome.") The actual Chrome layer is usually pretty thin because it's only there for appearance and hardness - which leads us to the real reason it's not clear coated. Generally speaking, chrome is too hard and and not porus enough to get any kind of paint to stick to it. (Just ask anybody who simply painted a chrome bumper.) Another reason most manufacturers don't do it? Cost.
How do you easily find out if you've got it or not? Try a continuity tester. Paint is generlly a pretty lousy conductor. Chrome plating on the other hand...
Another very simple way to test (because I'm allergic to electrical meters and other items) is to take a tiny little dab of metal polish on the tip of your finger and rub it on the metal...
If your finger turns black - it's uncoated. If you get absolutely no black coloring from the vigourous rubbing, it's coated.
If coated, treat it like paint. If uncoated, proceed with the metal polish.
-RP-
-RP-
On all the chrome I've ever polished, whether it be with a specific chrome polish or an all purpose polish, I've never had an black residue appear. I thought that was only on aluminum that you got that? Well, I'm sure theres other metals as well, but I didn't think you got any black residue from chrome. Wouldn't that make the dab of polish on the finger test kind of difficult to judge. Then again, maybe I'm just wrong. Wouldn't be the first time, won't be the last.
