Bleaching microfiber towels
hey,
i was wondering if it's ok to use clorox when washing microfiber towels?
most of my microfiber towels have black marks on there from dirt, or whatever I used them on last, and i miss that clean look on them, and i fear that the dirt is still on there and will come off on my paint
thanks
thanks
Originally Posted by spitfiresk822
hey,
thanks
thanks
Pre-soak the dirty areas with laundry detergent, or Micro-Restore products.
Scrub the dirty areas by hand with the pre-soak still on the towels.
Wash them in hot water.
Add some distilled vinegar to the rinse water... teaspoon or so per towel.
Rinse them again with no vinegar. Check the rinse water... if it is still "sudsy", rinse them again.
Dry them with medium heat, or air dry.
They will be clean, soft, and will work great.
RR i was thinking of using that stuff...looked on detailcity i believe and found it...but i was also contemplating the Chemical Guys concentrate microfiber detergent....im assuming you have great luck with that stuff? I am going to be so broke for a while...had a big order from ADS and AG....whooops
I used it 100% but found it works better if I use it 50/50 with regular detergent.
Cheers
