Tree Sap
Originally Posted by Ftruck05
First thing would be Bug and Tar remover, If that doesnt work I have heard of guys dipping a Q-Tip in rubbing alcohol and rubbing the sap only
RA is used as an antiseptic for sterilizing surfaces or cleaning minor cuts or abrasions, so my question is, what exactly does the RA do to the tree sap to remove it from the paint?
You want to go get a clay brick. They use them to remove paint overspray and road tar, and they work wonders on tree sap and bugs. I'm sure you can find one online, but I got mine from a automotive paint supply store. They use them in prep work before paint. They're solvent free, and won't harm your paint.
LOL
Sap, an alcohol and an aldehyde based substance, is an isoprene (notice how similar it is to Isopropyl), and both rubbing alcohol and sap are hydrocarbons.
In essence, these are both very similarly structured (well, not really, but close enough to what we need to do) polymers, thus they are soluble in each other.
So what happens? The rubbing alcohol reduces the sap into a liquid form once again to be removed with a high-quality rag. Alternately, you could simply spread the sugars around (sometimes nearly invisible), but that is a good way to attract bugs...
That help explain it? Clear as mud?
FWIW-- I would go for a wash and clay, then rewax.
