New trick to cleaning wheels and tires
Old 12-24-2007, 12:15 PM
BruceinGa's Avatar
Comet and liquid floor wax
Originally Posted by XL1200Ltd-Keith
I have been using Comet on the tires since 72 without any problems. It works great. Raised white letters look new after a good scrubbin'!
Looks like we're form the same era!
After scrubbing the tires I would put a light coat of liquid floor wax on the sidewall. The next time I cleaned my car I would scrubb the tires again with Comet and then apply the wax again. It would give the rubber a nice wet "shine".
Old 12-26-2007, 02:08 AM
stud_135's Avatar
Wow this is an interesting thread..i cant imagine using comet on anything...i know things get really dirty but like others mentioned there are a lot of other routes that can yield the same results..even with a cleaner this abrasive and dangerous..your tires and wheels can only get *so* clean. For the tires Simple Green 1:1 is a great option and readily available...but wheels i feel can get a bit tricky.. for most factory wheels you can get away with a bit more but aftermarket are a different story. If you do any other vehicles you ahve to have a regimen that agrees with all surfaces..here is something that i have found to be excellent...but gurus please chime in if u think this isnt a good option:
I take a car wash soap that i have fallen out of love with. In my case it would be Meguiar's D-Line Shampoo plus. I dilute 1:1 with water (yes 1:1) and use it as a degreaser. As always keep this kinda dilution rate off of the paint but i feel that instead of harmful chemicals i use a strong version of safe ones even for tough grit and nasty
Quick Reply: New trick to cleaning wheels and tires
