Order of applying detailing products
Well, after reading the C&D forum, I have the OCD bug! I bought a few products and it looks like I will spend a few days working on my truck making it look good. I have many of the necessary components described in the sticky, but I am confused as to when I should do certain steps. I do plan on claying my truck and then applying the wax. (Meg's clay kit, cleaner wax, and NXT 2.0). I also bought a touch up bottle of paint to cover some scratches and chips on the body of my truck. My question is... At what step should I use the touch up paint?
Here is what I have setup in my mind so far... Keep in mind I have already washed the truck.
1 Clay
2 Touch up paint
3 Wax
or...
1 Clay
2 Wax
3 Touch up paint
or...
1 Touch up paint
2 Clay
3 Wax
I know there is a correct procedure somewhere out there, I just want to get it done the proper way.
Any links to threads or personal experiences is greatly appreciated!!
1 Clay
2 Touch up paint
3 Wax
or...
1 Clay
2 Wax
3 Touch up paint
or...
1 Touch up paint
2 Clay
3 Wax
A complete detail should always be taken from this base.
Wash
Clay
Polish
Seal
Wax
From that point, you go into maintenance mode until it is needed again. sometimes that is 4-10 times per year pending how OCD you really are.
As for touch up....I would Wash, then touch up and allow that to cure. Wait a few days, Wash again, Clay and be careful of the areas you touched....then wax.
If it were mine that is what I would do. How much touch up do you need? 5 spots, 100?
JP
Wash
Clay
Polish
Seal
Wax
JP
JP
JP
Originally Posted by oceanic64
Speaking of touch ups dose anyone know a good system with proper brushes and technique? I have some stone chips and every time I try a over the counter It either blobs on or just looks like amaturer attempt. There must be a system of some sort that gives professional results!
you can either try a tooth pick or some very fine artist brush. I have yet to master it but am getting there. I have a nice spot I need to attend to on my truck door due to previous owner.
