Cleaning water spotted glass/mirrors
Glass: Use Bar Keepers Friend to remove water spots on glass and mirrors. With a damp cloth, wipe with a small amount of Bar Keepers Friend. Dry and buff with a soft cloth for best results.
Q: Can I use Bar Keepers Friend to clean windows such as windshields, shower doors, mirrors, etc...?
A: Yes, Bar Keepers Friend does contain a mild abrasive, but will not scratch glass.
That's from their website.
Originally Posted by attworth
I think your biggest problem is what you're using to wipe off the stoner's or whatever you're using. MF is key here. Newspaper use to be great, but not anymore as RR mentioned. Regularly terry cloths are going to streak.
Find yourself some good MF towels for windows and you should be fine.
I never had waterspot problems that were severe. Clay seems to work wonders but you might try using the stove top cleaner that is used on the glass top kitchen stoves. I believe I got it at Home Depot. Its similar to applying a compound. sponge it on and rub it in, when it dries to a haze, wipe it off
I should update the thread...
My windows are clean. I used a products called Nothin's Better to get the spots off. The product is from a local glass shop (and maybe other places?), and is a fine white powder... it is abbrasive enough to get the spots out, but not too harsh that it scratches.
After the spots were gone I followed up with some Rain-x for a little protection against the sprinklers.
