Need Help Now
I dunno about too much lube... There gets to be a point when you are wasting, but at first, I typically reccommend using more than enough until you get comfortable with knowing how much you need to use.
In any case, make sure you DO lube it up.
Also, it doesnt REALLY matter what you use as lube (within reason, of course). Any QD will work fine, as will a diluted wash solution. I wouldnt go much further than that, though. I guess what I am trying to say is, Use the lube that is cheapest-- it wont make a difference if you use QD #1 or QD #2-- as long as you are using something that is appropriate for the situation, you are fine...IMO, at least...
