can you reuse a clay bar
Originally Posted by miller
hi there im claying my truck tommorow and i was wondering do i throw the clay away after using or keepit and use it again o and ya does the meguiars
clay kit come with the clay lubricant thanks
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
Originally Posted by gators241987
if you need a lube, final detail works great!!!
Thanks,
Devildog101
To the original poster, the Megs Smooth Surface Kit comes with quick detailer, 2 50g clay bars, a sample of cleaner wax and 1 microfiber.
Originally Posted by bangingd
Also remember to cut the bar into a couple of pieces and if one is dropped and hits the ground throw it away. It is not worth the scratches you could put it by using after.![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
I reuse mine alot. THink about it like this, you use the clay bar to remove contaminents off the surface. As you remove them they build up in the clay. The point of the clay is to capture the contaminent and contain it within itself. So as you are removing the clay in absorbing sap, paint, tar, etc... As you fold and mead the clay, it still has the junk in it. Even a dirty clay bar can make alot of headway on a surface that is in need of help. Clays expensive, and buyin as much as I do, I know how long it will go before it is wasted.
