need advice on products
I am about to place an order to detail my truck and I need some final advice. I have a white Screw that has minimal scratches and few light swirls. I just want to keep it looking good without being too ocd. So here is what I have come up with....
PB SSR1 P21S PWC
PB EXP or Megs NXT
Natty's white P21S 100% Carnauba
Of course I am going to start with clay ( the truck badly needs that). Now I am thinking about using a PC 7424. What do you guys think? Do any of the P21S products have to be used ONLY by hand ? Is there anything else I should add ? Also keep in mind I am trying to keep costs down while doing a quality job. So if I had to I would spend the time and effort to do it all by hand and some good MF.
PB SSR1 P21S PWC
PB EXP or Megs NXT
PB SSR1 P21S PWC
PB EXP or Megs NXT
PB SSR1 P21S PWC
PB EXP or Megs NXT
I like the PB products myself.
SSR1 is pretty light, about as much cut as Megs 80, then pad choice becomes the factor. I wouldn't go more than a Green Lake for that, prob better to use a White lake with SSR1 if that is your correction step.
that PWC are you referring to PB Polish W Carnuba?
I also prefer the EX-P due to the cure time. You can top LSP over EX-P in as little as an hour.
For white a good combo is as follows:
Wash
Clay
Paint Correct with SSR1
PB Professional Polish
ClearKote Vanilla Hand Moose
EX-P
Collinite 845 LSP or Nattys
Or
SSR1
Menzerna Micro Polish
EX-P
Collinite 845 or Nattys
Or
SSR1
PB PP
EX-P
Nattys
White is tricky.
EDIT: Opps you said by hand right? Ouch, ok, well the products dont' really change, I would use PB for sure, they are "by hand friendly"
Just know that you won't get the same results until you migrate to a DA.
RR has given you some excellent advise and recommendations.
The secret to getting white to POP, as with any color, but particularly on white, is to get the paint clean, bright and reflective. His recommendations include the necessary cleaning/polishing steps to make that happen.
I think any of Steve's LSP products or the P21S pure carnauba will be fine choices.
I have two additional comments...
First, while NXT 2.0 is a fine product, I don't particularly care for it on light colors because of it's tendency to darken the paint... which sometimes has a negative affect on light colors.
My other suggestions is a bit a curve ball...
If your paint is in good condition as you suggest, you can clean and final polish all in one step by using Mothers Pre Wax cleaner, your PC, and a polishing pad.
Yes, I know, it's a "cleaner". However, it turns out that it is an excellent finishing polish when used properly. I like it almost as much as the Menzerna finishing polishes, and it is a LOT less expensive.
Spread it around at a speed of 1 to 2.
Work the area with several slow passes at 3 to 4.
Make a couple of final passes at 5.
Let it haze.
Wipe it off.
Have fun!
Let it haze.
Wipe it off.
Have fun!
sorry that should read :
P12S paint works cleaner (PWC)
megs nxt
P21S 100% carnauba
or
PB SSR1
PB EXP
Natty's white
I think I will save myself some effort and get a DA. Is there any difference between the PC 7424 and the Megs G110 ? I also am limited who I can order from being that I am in Canada. I have found that Autogeek does ship to me and they have most of the things I need.
Thanks for all the help !!!!!
megs nxt
P21S 100% carnauba
or
PB SSR1
PB EXP
Natty's white
megs nxt
P21S 100% carnauba
or
PB SSR1
PB EXP
Natty's white
megs nxt
P21S 100% carnauba
or
PB SSR1
PB EXP
Natty's white
megs nxt
P21S 100% carnauba
or
PB SSR1
PB EXP
Natty's white
megs nxt
P21S 100% carnauba
or
PB SSR1
PB EXP
Natty's white
If I use SSR1, PP, EXP and Nattys can they all be applied and removed with a DA ?
BTW, I also have a white truck and use the following combination after wash & clay.
Megs #80
ClearKote Vanilla Moose
PB's EX-P
Collinite 845
Can't wait to see pics when you are done!
ok so I appreciate everyones patients with me I'm kinda slow some times.
SO if I get this right you apply and work a product with one pad and then wipe down the surface with a MF towel ? How do you know what pad to use with what product ? I am thinking about the PB world DA polish and protect package on Autogeek.net. It comes with 3 kinds/colors of pads. I assume you would use the Orange with SSR1, white would be for the PB PP, and black for the EXP and Nattys by hand ? Any advice is greatly appreciated.
Ok, you are asking more detailed questions now. Have you seen the sticky on detailing? Or the one on Detailing Dictionary?
You DO NOT WANT TO USE A ORANGE pad with SSR1, assuming those are Lake Country pads.
To quote myself
LC
Lake Country. Maker of high quality buffing and polishing pads. (Three lines of Pads, VC=Variable Contact and CCS=Collapsed Cell Structure, LC Flat Pad
Six Pads of Various Cut and Polish.
Yellow & Orange Cutting: Designed for moderate oxidation, scratches and acid rain damage. Use with medium cutting products: (paint levelers and compounds) Yellow is more aggressive than Orange.
Green & White Polishing: Designed for light oxidation, scratches and surface swirls. Use with light cutting products: (polishes, swirl removers, pre-wax cleaners) Green is more aggressive than White.
Black & Blue Finishing: Designed for final prep & surface protection products. Use with light one-step cleaner/waxes, glazes, paste waxes and polymer sealants. Blue is the finest texture and has no cleaning ability.
To answer your question. I would use a Green Lake Pad with SSR1 or a yellow Megs pad. Then with the Pro Polish I would use the White Lake Pad.
For EX-P, I would use the Blue pad (black absorbs too much for me) then Apply Nattys by hand.
