Effectiveness of #7 by hand?
The DC polish has the same issues - a PITA by hand, it's got to be polished in and if it dries you will be kicking yourself. I did mine with it after the clay and wished I had used a regular old cleaner wax instead. I did finish with NXT 2.0 and that stuff is a dream to use by hand.
If #7 or DCP dries BEFORE you make it to removing it - or if you over work it to a dryness that is tough to remove, simply lightly spray the areas that need to be removed with a hit of DI Water. The water will make your work light years easier...
Also, some QD sprays work pretty well for the same task...
-RP-
