detailing experts help needed (ie rockpick, rollingrock, etc)
Im hoping that someone with more knowledge than myself can help me with this problem. I DJ on the weekends, as I have for roughly 8 years or so, anyway - about 4 years ago I bought an enclosed 6x10 Pace cargo trailer with a ramp door on the rear and side door. Its jet black with silver painted frame and a silver roof, that im pretty sure is maybe just unpainted aluminum? When i bought the trailer, brand new, it absolutely gleamed and stayed that way for a couple of years. I had asked the dealer when I bought it how to keep the trailer's finish looking good and I was told nothing, the aluminum finish wasnt like a car's paint so I wouldnt need wax or anything of that nature. Just wash it when it gets dirty and be done with it. Well fast forward to now, my trailer is anything but gleaming. Its black finish couldnt be any duller. Ive washed and scrubbed and cant seem to get it to shine. I dont know if its mildew or what but its horrible looking. The frame has spots of surface rust showing where the silver paint has chipped, but thats easily fixable. I was hoping someone might know of some secret to restoring the finish on this trailer. Ive looked all over the web and even asked other trailer dealers and nobody can seem to give me an actual answer, they all just say wash it but washing it does nothing, the dull stains and coloring never go away.
Thanks for any light you can shed on this.
If it is in fact paint, you just need to go through the detailing cycle. On a towing trailer, it may not be worth while to clay it. You can if you want to though. After that, you will need to clean the paint. I have only really used Meguiar's, so I can help you with those products.
In the Meguiar's line, you can use a product like M80 Speed Glaze. It is a cleaner/polish. You may want to use something like this to save you a step. It will help remove swirls, scratches, and oxidation. It will also add oils to the paint to make it look darker and shinier. M80 is best utilized by machine, but can also be used by hand. As for the wax, Meguiar's NXT 2.0 is a really good choice. It is a full synthetic wax with much better durability than the original. As for the aluminum roof, grab yourself a Powerball, an electric (plug in) drill, and Meguiar's Hot Rims Mag and Aluminum polish. The polish on the powerball yields superfast, great looking results.
Any pictures?
Any pictures?
I'm going to have to defer to needing pictures as well... I concur with JGG in that it sounds like it's likely single stage with oxidation but, it's a tough call to advise without really seeing it up close.
Just curious... have you tried rubbing on a spot with a product like cleaner wax? If so, did your pad/finger/toe turn the color of the paint?
I'm surprised RR hasn't chimed in. He seems to take good care of his camper. I'm sure it has a similar finish.
There are actually vehicles still produced today with single stage paint. Usually blacks and reds. If they said it wasn't like an automotive finish, maybe it is a painted gel coat?
EDIT- here is from the Pace website:
EXTERIOR SKIN MAINTENANCE
Clean exterior aluminum streaks with Black Streak Remover. Wash exterior often with a soft brush and a quality RV or Trailer Wash and Wax solution.
