More cut than #80
I've heard the same thing. But again..you might want to wait on somebody with a little more experience.
this is off of ADS
this is off of ADS
Moderate abrasive power removes light to medium contamination. A touch more aggressive than Meguiar's Swirl-Free Polish, our Dual Action Cleaner Polish effectively deals with more significant stains, swirls, blemishes and oxidation. Its safe, Buffered Abrasive™ cleaning action attacks defects while guarding your finish against scratches. Rich polishing oils ensure a memorable shine. Made For Professionals. Paintable! Safe for use in the paint shop.
Kevin
#83 is more aggresive than #80. If used properly #83 works very well in my opinion. You have to understand what is meant by Dual Action Cleaner Polish. It does not mean that it is speacially made for a DA it means that the polish is a cleaner at first but once it breaks down more it will leave a very nice shine. Many have said that it will leave micro marring on black and other dark colors. They most likey either worked it too short or too long. Like I said, if used properly it is a great product in my opinion.
I hope this helped some.
Devildog101
Devildog101
I was really just seeing what the best option was IF I needed more cut. With the paint I have dealt with so far #80 a Megs polishing pad and 10lbs of pressure is working just fine. Thanks for the help though.
Honestly, I'd forgo the #2...
While it is a decent product, it tends to dry much quicker and thus, you don't get the overall opportunity that may be needed to provide an adequate cut.
As is true of many products, #83 will be a tad oilier and thus allow you more time to work and properly break down the product so that it does the work that is necessary to yield a great finish.
#83 on a polishing pad...
