Oily Residue Cleaning
After removing my NXT Wax/Sealant, sometimes it leaves behind a sort of oily residue in random small spots that's a PITA to remove. Normally it happens on the hood or flat surfaces like door panels
Is this normal and indicative of me needing to put my elbow grease into my MF towel to remove the stuff, or is there an "professional anecdote" to resolve this?
It's not easy to see, but upon close inspection it's there.
Thanks!
Thanks!
I am interested to hear the answer to this, too... So far, I have decided that it comes from having too much product sit for a bit in one place, but this is only a guess... My paint almost always looks blotchy until I QD it...
My solution has been to:
1. Apply wax
2. Remove wax (this is where you see it, right?)
3. QD the entire truck. It seems to even it out...
1. Apply wax
JP-- after using #21 again for the first time in ages, I can now remember why I liked EX-P so much. I know, I know, you told me so... (memories of EX-P, Nattys Blue, SSR 3, SSR 1, and S&W just flooded my head... And the flavor of Nattys Red!!! )
BTW-- for some reason, that pink FK #425 pops into my head... Is it depth/pop-enhancing or just a QD? I cant remember... Is it any good?
100% AGREED. I usually let #21 sit on there for about 45 mins before removal, then I wait to top it until 24 hours because of the streaking. After 24 hours, I QD (to remove dust mainly, but it helps a touch) then use #26. No need to QD again after #26 unless you just feel like it OR you are using somethign like 4-Star Ultimate Gloss Enhancer or UQD.
funny, I just ordered more EX-P and a full set of Lake CCS pads from SM.
Dont rub it in... If I had the space to put more goodies, I would (and I think you know it, too...) By the way, did I tell you that I have the other wrench? Perhaps I can bring it by one weekend... How soon you need it? If necessary, I can mail it over there.:o
I don't need it right away but if you are in the area, you know the "special hiding" place I use for drop offs and pick ups if you are in the area.
(Shhhhh, the hose wheel cart)
