Black Hole
Black Hole
quick question i think i got it right though my routine is
Wash with gold class
clay-megs consumer
paint cleaner/scratch x-megs
Black hole-polishing pad on 4??
Do i need another product here? i have a megs polish(consumer step 2) i also have some #7 need help here!!!!
Nxt by hand 2 times 12hr intervals
1 coat Caranuba by hand 24 hr after nxt.
If some one can fill in my blanks and give me some pointers please. thanks in advance
clay-megs consumer
clay-megs consumer
clay-megs consumer
Looks like you are doing a full detail, so that in mind, the process should be:
wash
clay
polish
glaze
seal
LSP
Based on your list, you don't have a polish step. Add that after clay and you are good to go. Not sure about using the Megs two step stuff, haven't used that in years.
JP
PB black hole is not a polish, it's a glaze however, that being said, it was designed to give you a "in between" full detail product and as a glaze. It does have some concealing properties to it
wash
clay
polish (ssr1 or 2.5?)
glaze (blackhole)
seal (EX sealant)
LSP (natty's blue)
wash
clay
glaze (blackhole)
seal (EX sealant)
LSP (natty's blue)
Yep. For the polishing step I presume you were going to use SSR 1 first to see if it would cut it, then if not move to 2.5. Note, though, that after 2.5 you will have to follow up with the SSR1.
You did forget a crucial step first then again last-- TAKING PICTURES!!!
Good luck, and be sure to let us know about the results
wash
clay
polish
glaze
seal
LSP
JP
wash
clay
polish
glaze
seal
LSP
JP
Maybe one of the guys with more megs experince can jump in here. When you say basic megs, what is that? Like #80? or the do you mean the cleaner/wax combo product ?
Ok...to your question...what products and pads do you have?
Gold Class wash
Megs paint cleaner
megs polish
megs scratch x
pb black hole
nxt 2.0
mothers carnauba
me and my friend split a da he has all the pads i know their all megs but not sure which ones. also i was just about to purchase ssr3 and PB EXp should i purchase them.
Wow im sorry jp that was wierd i checked the thread before and i got no answer sorry okay i have
Gold Class wash
Megs paint cleaner
megs polish
megs scratch x
pb black hole
nxt 2.0
mothers carnauba
Gold Class wash
Megs paint cleaner
megs polish
megs scratch x
pb black hole
nxt 2.0
mothers carnauba
Also, find out which pads he has... it makes a difference...
And, note that if you use SSR3, you need to follow it with SSR1 or some other light abrasive. SSR3 is pretty gritty, so you will need to remove the haze it causes.
I LOVE EX-P, so I would definitely recommend it... Although if you are trying to save $$$, the NXT 2.0 is also a sealant, so you could snub the EX-P and use NXT instead... Follow whichever one you use with the Mothers Carnauba-- just wait about an hour if using EX-P or 10 hours if using NXT.
F150sport hit it pretty good, but honestly, without a close up photo in the light of what you are dealing with its hard for me to tell you which SSR's to get.
If budget is no option get them all. If you are wanting to get in to PB products EX-P should be a staple product to own so should PB PP. (Pro Polish)
the must have from PB's are
SSR1
PP
EX-P
pending color, WD or BH
Any Nattys unless you have a fav LSP already.
Those would be equal to Megs #80, #07 and NXT (I think) and then #26
SSR1
PP
EX-P
I LOVE EX-P, so I would definitely recommend it... Although if you are trying to save $$$, the NXT 2.0 is also a sealant, so you could snub the EX-P and use NXT instead... Follow whichever one you use with the Mothers Carnauba-- just wait about an hour if using EX-P or 10 hours if using NXT.[/QUOTE]
Yes those are the products Thank you very very much i think i got everything i need and everything to calm my ocd. oh the pads came with the DA im assuming there cheap (6" DA White Foam Waxing Pad
6" DA Black Foam Finish Pad
6" DA Yellow Foam Cutting Pad) the kid i went half with dosent care so much about his product choice. i guess im going to need some pointers on pads now. im gonna go with the lc's just tell me which ones thankss soo much guys this is really helping.
