Poorboy's Detail (pics to come)
Not all speeds are the same based on those same factors. Hard to track but good intent and idea.
so one can use BH as a maintenance product to produce a little more shine? i have to re-wash my truck from all the water spots, and i thought about going over it with BH for a little more pop. will it remove any wax or sealers?
Speeds are variable based on product, correction, pad, time etc. That means there are are many factors involved. Sometimes if a certain speed isn't getting it, you need to kick it up...., or if its too much, kick it down....that being said, its hard to remember all the places you used what speeds with what combo to solve X problem or stage in the process.
I just finished a black CTS-V and 4.5 is usually my speed for #80 but I had to go to 5 on the caddie. And yes I'll have pics. I had to go before I had time to wipe the LSP off.
I'm not 100% but I would say that it would remove some if not all of the wax or sealant. You would probably be better off applying BH then following up with another layer of wax or sealant.
Since BH and WD can also be used "in between" full details you will need to re apply any sealer or LSP. The protective elements of a sealer and LSP should be breaking down over time anyway between full details so its a good idea.
Personally, if using in between, I would just apply an LSP to get you buy until you are ready to do another full detail.
Hope that came out right, I gotta go cook breakfast for everyone.
Cheers from site 82.
