Rubbing out very light scratches
Probably a dumb question, and I searched a little, but didn't really find what I was looking for (I know that's what everyone says!).
Anyway, I was driving on a dry, dusty offroad trail with sage brush lining each side of the trail and sometimes it got a bit narrow.. It was a blast though!
The scratches go from the front fender to the rear tail light on both sides. Maybe a dozen 'lines' on each side within a 12" strip, but are so light that you can't even feel them. You have to come up to within a couple of feet to even see them...
I've got some Meguires Scratch X, but my question is, do I have to do the whole panel (from top to bottom) or can I just work in the 12" strip where the majority of the scratches are?
I've not even done a 'test' area yet, but thought I'd toss the Q out to the detail experts anyway!!
Thanks!
Mitch
Thanks!
Mitch
Thanks Dan,
That's what I was thinking too. The truck is the stock 'Royal Blue' or whatever name it is for the dark blue metalic, so I'd bet that this color will probably show even more if I only half assed it and did only the scratches....
But, for the rest of the panel, I wouldn't have to work out any scratches, so do I still have to rub it as much as the area where the scratches are?
How much, if any of the original clear coat would be left on an 11 year old truck?? It's garaged kept while at home, but it is a daily driver too.. I've don't have any faded paint anyplace on it, so maybe there is still some clear coat?
Mitch
Mitch
Mitch,
If it were me, I wouldn't use ScratchX anyplace other than where the scratches are. In fact, I don't think I'd use it at all. While ScratchX does have some abrassives, it also has a whole lot of fillers. So it may do more hiding than removing...
I'd get some Meg's #80 Speed Glaze. It has a nice amount of "bite" to it, and it also leaves the surface looking very wet and glossy. And since you said that you can't feel the scratches, and can only see them up close, I'd bet that the #80 would take them out without breaking a sweat. Plus, if you use it on your entire truck, it will also remove some of the minor swirl marks that an 11 year old truck is bound to have.
Oh yeah, if you decide to go with the #80, be sure to put a nice coat of wax or sealant on top of it to seal in the shine. Meg's #26 or NXT 2.0 works well if you want to stay with Meguiar's.
