Best soap
Best soap
Well, I'm going to be placing an ADS order to get a few things. I am using the Gold class soap right now, is there one that I should get that is better? I'm using the two-bucket hand wash method and it seems to be working pretty well. I also need a new wash mitt - how are the SM Arnold Lambswool? Basically, I need recommendations on the following items that I'm going to be buying:
Wash soap
Wash mitt
Drying towel
Leather cleaner/conditioner
Engine cleaner
Detailer for interior vinyl/plastic
Detailer for claying/in between washes
Wax (I like the NXT 2.0 a lot)
Clay Bar
Tire dressing
Anything else I need?
Any help is appreciated!
Wash soap
Wash mitt
Drying towel
Engine cleaner
Clay Bar
Tire dressing
Wash soap
Wash mitt
Drying towel
Engine cleaner
Clay Bar
Tire dressing
Wash soap
Wash mitt
Drying towel
Engine cleaner
Clay Bar
Tire dressing
I get my order in tomorrow but I won't get to start on the truck until early saturday morning....I'm already getting giddy thinking about all the new stuff I get to play with!
I've only recently start experimenting with Meguiar's Professional Line products. Most of my experience has been with Tropi-Care, but there are plenty of guys on here that can offer more educated suggestions. Based off of the litte Meguiars experience that I have I would recommend:
Wash soap - I really like the Gold Class myself
Wash mitt - Last time I checked they didn't have any of the SM Arnold but I hear they are awesome. The concensus is that you should wait until they get more in.
Drying towel - My only experience is with Tropi-Care Waffle Weave towels. I don't know which would be better between the Water Magnet of the Soft Touch.
Leather cleaner/conditioner - Again, I've only used Tropi-Care and Lexol. A lot of guys seem to like the Gold Class Cleaner and Conditioner products.
Engine cleaner - All Purpose Cleaner
Detailer for interior vinyl/plastic - As far as Megs goes I really like the Gold Class wipes. I usually use Vinylex unless I'm just "touching up" the interior.
Detailer for claying/in between washes - I like the Ultimate Quick Detailer, but I'm going to try #34 next. Thumper really seems to like it...plus I like to buy in bulk sizes.
Wax (I like the NXT 2.0 a lot) - I used 2.0 for the first time Sunday and I also liked it. #26 is my favorite Megs wax, but then again I've never had the opportunity to try #16.
Clay Bar - I've always used Tropi-Care or the Meguiars Smooth Surface clay kit. I would really like to give the aggressive red and mild blue clay bars a shot.
Tire dressing - A lot of guys on here get great results with Hyper Dressing, which you'll want to get regardless. I can't get away from the Michelin tire spray.
Anything else I need? Don't skimp out on the MF Towels. You will use a lot more than you think during a detail. You may also want to get a number of Hi-Tech applicator pads and a Grit Gaurd if you don't already have one.
Wash soap
Gold Class is great, Megs Super Soap is nice too. I like to mix a little QD in with my wash for a more "slick" feel. Predominantly XFD (see QD note below.)
Wash mitt
http://www.waxstation.com also carries the SM Arnold Mitt if you absolutely cannot wait for ADS to get more. I've heard it's wonderful.
Drying towel
Once you have a good wax on your truck, you should be able to "sheet" the water off using a water hose without any connections - see detailing sticky for more info. After "sheeting," use a waffle weave towel to "blot" the surface dry - NO rubbing whatsoever.
I've heard Meg's 2-step is good. I've personally only used the OTC Meg's cleaner/conditioner.
Engine cleaner
There's more info in the sticky, and other threads. Simple Green or another APC (All-purpose cleaner,) will work well. I personally use APC+. Use extreme caution when cleaning your engine and do so at your own risk.
Poorboys Natural Look Dressing from http://www.specialtymotoring.com works great and smells wonderful. Doesn't leave a sticky/oily residue if used properly.
I assume you mean a quick detailer (QD) to skip washes when you're just dusty - probably not a good idea. However, RollingRock did an extensive review of SEVERAL QD's a week or so ago. Do a search for that one - it has tons of good info.
NXT 2.0 is great. If you want to top it for added "pop," use something like Meg's #26 12hours after applying the NXT
Clay Bar
Meg's Clay Bar kit from Wal-mart works just fine, but for something a bit more aggressive, the Blue (mild,) kit works great. Don't forget you can use the soft (walmart clay,) on your windows to help remove water spots/bug residue
Tire dressing
Hyperdressing - there's tons of threads. Literally hundreds I'm sure. This stuff is great. Thanks to RP and RR for turning everybody on to it.
Patience and a little knowledge. Read around here for a few weeks and definitely check out the stickies. There's some nice videos you can watch (mentioned in another thread yesterday,) about how to go about some of these things we do. Oh, and beer helps for those long details
I agree. I still use distilled water with car wash soap. I know it requires a second wash, but it's what I'm used to.
I will answer in bold. I love ADS, but I will recommend my favorite, which is bought at more than one site.
Wash soap- DP soap, zaino z7 and Pinnacle
Wash mitt- sm arnold
Drying towel- pakshak WW
Leather cleaner/conditioner- leatherique
Engine cleaner- apc, super degreaser, and cd2
Detailer for interior vinyl/plastic- 1Z cokpit premium
Detailer for claying/in between washes- fk425
Wax (I like the NXT 2.0 a lot)- p21s100%, fk carnuba pink wax, pinnacle souveran
Clay Bar- clay magic
Tire dressing- zaino z16
My favorite soap by far is Duragloss 901. There are a lot of gold Class fans on here but I think DG901 is better. I picked up some really nice sheepskin mitts from Big Lots for $4. Better than the $12 ones I was buying elsewhere. Very thick and plush. I have a few sample packs of the Duragloss if anyone would like to try it out. I dont use soap much anymore. I use ONR unless my truck is really dirty and that is rare. My fave QD's right now are ONR diluted, Clearkote Quick Shine, FK425, Poorboys S&W and Duragloss Fast Clean & Shine
Answers in bold.
My favorite soap by far is DP Foam Gun Shampoo. It's got insane amounts of lubrication and suds. It's expensive though ...
Wash soap = DP Foam Gun Shampoo, it's expensive though. If you want something cheaper, go with Gold Class or Super Soap.
Wash mitt = SM Arnold Lambs Wool Mitt, by FAR !!
Drying towel = Meguiars Water Magnet.
Leather cleaner/conditioner = I like the Meguiars Leather Cleaner/Conditioner that comes in the 1 gallon and 5 gallon bottle.
Engine cleaner = Meguiars APC+, by FAR !! It's one of my favorite products, as well as the correct bottles for them. The bottles have the proper dilution ratios, I'd buy two gallons of it.
Detailer for interior vinyl/plastic = Meguiars Interior QD
Detailer for claying/in between washes = Meguiars #34. It's kind of expensive for claying but I use it for after washes and full details. I use the A-Line QD for claying since it's cheap.
Wax (I like the NXT 2.0 a lot) = Meguiars #16, by FAR !!
Clay Bar = Poorboy's Clay
Tire dressing = Hyperdressing, by FAR !! Order two gallons, as well as the correct bottles for them. The bottles have the proper dilution ratios. I've got one bottle for 1:1 and one for 3:1.
My favorite soap by far is Duragloss 901. There are a lot of gold Class fsans on here but I think DG901 is better. I picked up some really nice sheepskin mitts from Big Lots for $4. Bettter thsan the $12 ones I was buying elsewhere. Very thick and plush. I have a few sample packs of the Duragloss if anyone would like to try it out. I dont use soap much anymore. I use ONR unless my truck is really dirty and that is rare. My fave QD's right now iare ONR diluted, Clearkote Quick Shine, FK425, Poorboys S&W and Duragloss Fast Clean & Shine
I completely agree. The Duragloss 901/902 is BY FAR the best OTC (Carquest only) shampoo that I've ever used (I've used Megs Gold Class as well as several of their "detailer" like shampoo's, and many others) The lubricity is fantastic, suds are plentiful, it cleans well without stripping the wax, and it smells great. I went through 2 small bottles of it before I splurged for the gallon container from Carquest. Also pick up a gallon of the Duragloss Aquawax while you're there. It costs about $30, but is excellent as a spray wax, and is great when used as a "wax as you dry" product.
Big Lots has Megs QD in spray cans for 3 bucks and Megs Quik Wheel Detailer for 3.50 too. I didn't bother.
