Stoners invisible glass
Old 06-18-2008, 10:04 AM
Les22's Avatar
Man, I did a search for a glass cleaner, and found out about Stoners.
That is good stuff- no haze or streaks like I always got with other glass cleaners
Old 06-18-2008, 10:06 AM
Yep, it's the shizznit!
Old 06-18-2008, 10:25 AM
j2h1's Avatar
Agreed!!!
Old 06-18-2008, 10:26 AM
Les22's Avatar
I wish I had enough to do the windows inside and outside on my house
One quick question- what are you guys using to remove the product with? I know paper towels are a no-no...although thats what I used
Old 06-18-2008, 10:51 AM
Micro Fiber towel, didn't know there was anything else.
Old 06-18-2008, 10:52 AM
The stuff is safe on tint, too.
Old 06-18-2008, 10:57 AM
last5oh_302's Avatar
Normally it doesn't streak, but the other day I tried it in the direct sun light. If you don't wipe it off immediately, it will streak. I need to do mine again, and I'm sure the only reason it streaked is because it was evaporating before I wiped it off. This is the first time I've ever had it streak so it had to be due to the sun. Normally it does a great job!
Old 06-18-2008, 12:44 PM
glc is offline
Stoner's is probably the best non-professional glass cleaner out there. Paper towels are fine - you can even use newspapers.
Old 06-18-2008, 02:43 PM
sal150's Avatar
Stoners is the Best!!
One problem is that the sprayer on it is like super charged gotta be careful otherwise youll be wipin out the Qd.
PB makes a glass towel, its a fine (velvet smooth) towel that works GREAT.
Old 06-18-2008, 03:04 PM
AsheFX4's Avatar
I really like the Invisible Glass Wipes too.
Old 06-19-2008, 09:59 AM
bogman's Avatar
Learned about Stoners here two years ago and it is the best. The wife swiped it when she ran out of Windex and now I have to hide it. Stoners tire shine is good to, not real shiny.
Old 06-19-2008, 11:38 AM
Grubrunner's Avatar
I don't know of any window cleaner that will NOT streak when applied in direct sunlight.... especially on a hot summer's day.
Spot on!
I've tried the wipes without being overly impressed. They, IMO, streaked considerably more than the spray/microfiber combo.
Old 06-19-2008, 12:46 PM
ThumperMX113's Avatar
A lot of professional guys even use Stoners. I'm not saying I'm a pro, I'd like to be able to say so one day, but I love Stoner's Aerosol Invisible Glass and I've never found myself using anything else but it. After using it, the glass is super clean and smooth. I also find the water beads up like it's waxed. I use dedicated microfibers as well. I find they work the best.
Old 06-19-2008, 01:27 PM
Iam4st8's Avatar
Do ya'll use the special microfiber glass towells? If so, why whats the difference? I know i just use a regular MF, it works great don't see why to change.
Old 06-19-2008, 01:29 PM
I've never tried a microfiber that simply is made for cleaning windows. Like you, I've never seen the need to do so. I use dedicated microfibers for everything I do though. I use the "blue" microfibers from ADS for windows, wheels, and interior.
Quick Reply: Stoners invisible glass
